[gdal-dev] Running GDAL through Python >= 3.8 on Anaconda - DLL load failed
Pedro Venâncio
pedrongvenancio at gmail.com
Wed Oct 13 06:20:05 PDT 2021
> But I don't understand why you still get the "On Windows, with Python >=
> 3.8, DLLs are no longer imported from the PATH." error message.
> It shouldn't be emitted because USE_PATH_FOR_GDAL_PYTHON is set:
> https://github.com/OSGeo/gdal/blob/f3a83a2c2628219bdc60001580da677758015a60/gdal/swig/python/osgeo/__init__.py#L25
> Something weird happening here. Perhaps edit
> to display os.environ
Even, I was not setting the environment variable correctly on conda. It
needs to be
conda env config vars set USE_PATH_FOR_GDAL_PYTHON=YES
and then I already get
conda env config vars listUSE_PATH_FOR_GDAL_PYTHON = YES
So, the error message had changed
python demo.pyTraceback (most recent call last): File "demo.py", line
1, in <module> from osgeo import gdal File
"C:\Users\PedroVenancio\anaconda3\envs\arosics\lib\site-packages\osgeo\__init__.py",
line 11, in <module> os.add_dll_directory(p) File
"C:\Users\PedroVenancio\anaconda3\envs\arosics\lib\os.py", line 1109,
in add_dll_directory cookie = nt._add_dll_directory(path)OSError:
[WinError 87] O parâmetro está incorreto: '.'
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211013/64f85839/attachment.html>
