[gdal-dev] Running GDAL through Python >= 3.8 on Anaconda - DLL load failed
Pedro Venâncio
pedrongvenancio at gmail.com
Wed Oct 13 06:36:20 PDT 2021
> Can you change in __init__.py
> try:
> os.add_dll_directory(p)
> except FileNotFoundError:
> continue
> to
> try:
> except (FileNotFoundError, OSError):
> continue
Yes, here is the output:
Traceback (most recent call last): File
"C:\Users\PedroVenancio\anaconda3\envs\arosics\lib\site-packages\osgeo\__init__.py",
line 21, in swig_import_helper return
importlib.import_module(mname) File
"C:\Users\PedroVenancio\anaconda3\envs\arosics\lib\importlib\__init__.py",
line 127, in import_module return
_bootstrap._gcd_import(name[level:], package, level) File "<frozen
importlib._bootstrap>", line 1014, in _gcd_import File "<frozen
importlib._bootstrap>", line 991, in _find_and_load File "<frozen
importlib._bootstrap>", line 975, in _find_and_load_unlocked File
"<frozen importlib._bootstrap>", line 657, in _load_unlocked File
"<frozen importlib._bootstrap>", line 556, in module_from_spec File
"<frozen importlib._bootstrap_external>", line 1166, in create_module
File "<frozen importlib._bootstrap>", line 219, in
_call_with_frames_removedImportError: DLL load failed while importing
_gdal: Impossível localizar o procedimento especificado.During
handling of the above exception, another exception occurred:Traceback
(most recent call last): File "demo.py", line 1, in <module> from
osgeo import gdal File
line 37, in <module> _gdal = swig_import_helper() File
line 34, in swig_import_helper return
importlib.import_module('_gdal') File
level)ModuleNotFoundError: No module named '_gdal'
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211013/15db3950/attachment.html>
