[gdal-dev] Running GDAL through Python >= 3.8 on Anaconda - DLL load failed
Joaquim Manuel Freire Luís jluis at ualg.pt
Wed Oct 13 08:23:40 PDT 2021
Não Pedro,
When I look into my own build of the gdall dll I see no dependency on that “opj_encoder_set_extra_options” but likely because it’s a different version (I build from master).
From my experience on this there is really nothing one can do other than rebuild the dll or replace the dependency that is missing the required symbol. Nothing we can do from a conda installation.
But ofc my analysis may be all wrong.
Joaquim
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Pedro Venâncio
Sent: Wednesday, October 13, 2021 4:04 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Running GDAL through Python >= 3.8 on Anaconda - DLL load failed
Hi Joaquim,
Thanks for sharing your case. Did you manage to make it work in some way?
I've already uninstalled a test PostgreSQL/PostGIS that I supposed to be the source of the conflict, but I keep having the same error.
I also reinstalled conda, but nothing had changed.
Joaquim Manuel Freire Luís <jluis at ualg.pt<mailto:jluis at ualg.pt>> escreveu no dia quarta, 13/10/2021 à(s) 15:24:
I have a certain horror to python (that I’m trying to fight) a bit of it is because I never manage to really use it.
I had and older Miniconda (Mini => 18 GB !!!!) that was so big that I removed and installed a new one in which I tried Pedro’s case and got exactly the same errors.
I then run a dependency analysis from within the conda shell and found two weird things
  1.  The gdal dll depends on a xerces-c_3_2.dll locate at C:\WINDOWS\system32. This seems quite dangerous (for dependency sakes) but seems to not cause any problem in this case.
  2.  There is a “red mark” on the opj_encoder_set_extra_options symbol and this alone can explain the “ImportError: DLL load failed while importing _gdal: The specified procedure could not be found.”
Hopefully the screen capture is small enough to get through.
Joaquim
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> On Behalf Of Even Rouault
Sent: Wednesday, October 13, 2021 2:39 PM
To: Pedro Venâncio <pedrongvenancio at gmail.com<mailto:pedrongvenancio at gmail.com>>
Cc: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
ok, so now you have to inspect the PATH and fix it so that the gdal DLL and its dependencies are in it. But all of this sounds like there's something weird in your environment. Perhaps a mix of GDAL versions?
Le 13/10/2021 à 15:36, Pedro Venâncio a écrit :
Can you change in __init__.py
                try:
                    os.add_dll_directory(p)
                except FileNotFoundError:
                    continue
to
                try:
                except (FileNotFoundError, OSError):
                    continue
Yes, here is the output:
  File "C:\Users\PedroVenancio\anaconda3\envs\arosics\lib\site-packages\osgeo\__init__.py", line 21, in swig_import_helper
    return importlib.import_module(mname)
  File "C:\Users\PedroVenancio\anaconda3\envs\arosics\lib\importlib\__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 657, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 556, in module_from_spec
  File "<frozen importlib._bootstrap_external>", line 1166, in create_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
ImportError: DLL load failed while importing _gdal: Impossível localizar o procedimento especificado.
During handling of the above exception, another exception occurred:
  File "demo.py", line 1, in <module>
    from osgeo import gdal
  File "C:\Users\PedroVenancio\anaconda3\envs\arosics\lib\site-packages\osgeo\__init__.py", line 37, in <module>
    _gdal = swig_import_helper()
  File "C:\Users\PedroVenancio\anaconda3\envs\arosics\lib\site-packages\osgeo\__init__.py", line 34, in swig_import_helper
    return importlib.import_module('_gdal')
ModuleNotFoundError: No module named '_gdal'
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211013/dc10ef0c/attachment-0001.html>
