[gdal-dev] Writing multi-bands vs multi-datasets
Even Rouault even.rouault at spatialys.com
Thu Oct 14 12:14:21 PDT 2021
Le 14/10/2021 à 21:03, Joaquim Manuel Freire Luís a écrit :
> Even,
> There are some issues with this way.
> My draft Julia function looks like bellow  (tested with a MxNx7 array)
> but get this errors
> julia> GMT.write_multiband(cube, "gd_cube.nc")
> Warning 1: No 1D variable is indexed by dimension time
> Warning 6: creation option '-co' is not formatted with the key=value
> format
> format
> format
I don't know the Julia bindings, but the error message seems to suggest
you can remove the "-co" element in your options[] array since it
presumably must only contain the "key=value" creation options, like in
the Python bindings
> ERROR 1: netcdf error #-45 : NetCDF: Not a valid data type or
> _FillValue type mismatch .
> at
> (C:\programs\compa_libs\gdal_GIT\gdal\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::CreateCopy,9012)
> ERROR 1: netcdf error #-49 : NetCDF: Variable not found .
> at
> (C:\programs\compa_libs\gdal_GIT\gdal\frmts\netcdf\netcdfdataset.cpp,NCDFPutAttr,10454)
> And indeed the “time” variable shows up filled with 7 zeros when I
> open the nc file that is nevertheless created.
> Also checked with getmetadataitem(ds, "NETCDF_DIM_time_VALUES")  that
> the "1,2,3,4,5,6,7" info was correctly set.
You need to surround the values of the _DEF and _VALUES items with { and
} braces to indicate this is a list (this is the particular syntax
expected by the netCDF driver)
> I’s also strange the warnings about the “-co” options also because
> they were in fact taken into account. Omitting them creates a classic
> nc file.
> function write_multiband(cube, fname::AbstractString, v=nothing;
> dim_name::String="time")
>                nbands = size(cube,3)
>                ds = gmt2gd(cube)
> Gdal.setmetadataitem(ds, "NETCDF_DIM_EXTRA", dim_name)
>                Gdal.setmetadataitem(ds, "NETCDF_DIM_" * dim_name *
> "_DEF", "$(nbands),6")
> Gdal.setmetadataitem(ds, "NETCDF_DIM_" * dim_name * "_VALUES",
> "1,2,3,4,5,6,7")
> Gdal.setmetadataitem(ds, dim_name * "#axis", string(dim_name[1]))
>                crs = Gdal.getproj(cube, wkt=true)
>                (crs != "" ) && Gdal.setproj!(ds, crs)
> Gdal.unsafe_copy(ds, filename=fname, driver=getdriver("netCDF"),
> options=["-co", "FORMAT=NC4", "-co", "COMPRESS=DEFLATE", "-co",
> "ZLEVEL=4"])
> end
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* Sunday, October 10, 2021 10:48 PM
> *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Writing multi-bands vs multi-datasets
> Joaquim,
> https://github.com/OSGeo/gdal/pull/4634
> <https://github.com/OSGeo/gdal/pull/4634> should hopefully help
> Even
> Le 10/10/2021 à 22:26, Joaquim Manuel Freire Luís a écrit :
>     Hi,
>     I have a Julia version of gdal_translate (that ends up calling
>     GDALDatasetRasterIOEx) that works in saving a MxNxP array, but not
>     the way I wanted.
>     It creates a multi-subdatasets file, whilst what I wished is to
>     write a multi-band file.
>     For example, the file written with this Julia function looks like
>     below
>     How can I write a multi-band instead of a multi-datasets?
>     I’ve been looking at the docs of GDALDatasetRasterIOEx but can’t
>     see any way of picking one or the other.
>     Joaquim
>     gdalinfo cube_rad.nc
>     Driver: netCDF/Network Common Data Format
>     Files: cube_rad.nc
>     Size is 512, 512
>     Metadata:
>     NC_GLOBAL#Conventions=CF-1.5
>       NC_GLOBAL#GDAL=GDAL 3.4.0dev, released 2021/99/99
>     NC_GLOBAL#history=Sun Oct 10 13:01:06 2021: GDAL CreateCopy(
>     cube_rad.nc, ... )
>     Subdatasets:
>     SUBDATASET_1_NAME=NETCDF:"cube_rad.nc":Band1
>     SUBDATASET_1_DESC=[1567x1519] Band1 (32-bit floating-point)
>     SUBDATASET_2_NAME=NETCDF:"cube_rad.nc":Band2
>     SUBDATASET_2_DESC=[1567x1519] Band2 (32-bit floating-point)
>     Saving the same data (or similar) from a Matlab code that I wrote
>     long ago to stack grids, shows
>     gdalinfo evi_cube.nc
>     Files: evi_cube.nc
>     Size is 37, 59
>     Origin = (580140.000000000000000,4418550.000000000000000)
>     Pixel Size = (30.000000000000000,-30.000000000000000)
>     Metadata:
>     latitude#actual_range={4416795,4418535}
>     latitude#long_name=latitude
>     latitude#units=degrees_north
>     longitude#actual_range={580155,581235}
>     longitude#long_name=longitude
>     longitude#units=degrees_east
>     NC_GLOBAL#Conventions=COARDS
>     NC_GLOBAL#description=File written from Matlab
>     NC_GLOBAL#node_offset=0
>     NC_GLOBAL#Source_Software=Mirone
>       NC_GLOBAL#title=Grid created by Mirone
>     NETCDF_DIM_EXTRA={time}
>     NETCDF_DIM_time_DEF={67,6}
>     NETCDF_DIM_time_VALUES={1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67}
>     z#actual_range={-856.4703369140625,176.8457641601562}
>       z#long_name=z
>       z#units=unknown
>     z#_FillValue=-nan(ind)
>     Corner Coordinates:
>     Upper Left  ( 580140.000, 4418550.000)
>     Lower Left  ( 580140.000, 4416780.000)
>     Upper Right ( 581250.000, 4418550.000)
>     Lower Right ( 581250.000, 4416780.000)
>     Center      ( 580695.000, 4417665.000)
>     Band 1 Block=37x59 Type=Float32, ColorInterp=Undefined
>       NoData Value=nan
>       Unit Type: unknown
>       Metadata:
>         long_name=z
>         NETCDF_DIM_time=1
>         NETCDF_VARNAME=z
>         units=unknown
>     Band 2 Block=37x59 Type=Float32, ColorInterp=Undefined
>       NoData Value=nan
>       Unit Type: unknown
>       Metadata:
>         long_name=z
>         NETCDF_DIM_time=2
>         NETCDF_VARNAME=z
>         units=unknown
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org  <mailto:gdal-dev at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com  <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211014/f1d7c6f1/attachment-0001.html>
