[gdal-dev] RFC 84: Migrating build systems to CMake
Greg Troxel gdt at lexort.com
Fri Oct 15 11:18:40 PDT 2021
Even Rouault <even.rouault at spatialys.com> writes:
> ==> I've thus gone to "git mv gdal/* ." to remove the gdal/
> subdirectory. Of course number of boring changes were needed to adapt
> CI scripts, Docker, mkgdaldist.sh, etc.  This will also impact
> downstream users building from git once that work will have landed
> into master. I'll wait for the release/3.4 branch to have been created
> (probably in ~ 10 days) before merging this. A side effect is that it
> will slightly complicate the workflow for 3.5 -> 3.4 backports, but
> that's a temporary inconvenience for a longer term advantage.
When it is time for release please start out with alpha, as from the POV
of packaging systems this is a big deal.   I would expect at least 30
days, probably >=45, from alpha to release, to allow people calendar
time to find the time to deal with transition, report issues, and get
them resolved.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211015/7bf48154/attachment.sig>
