[gdal-dev] RFC 84: Migrating build systems to CMake
Greg Troxel
gdt at lexort.com
Fri Oct 15 11:38:04 PDT 2021
Even Rouault <even.rouault at spatialys.com> writes:
> That git tree reorganization alone should hardly impact packagers
> still using autoconf, as the release tarball structure will be
> unchanged. This only impacts folks building from git
> The full cmake transition will certainly require more time, but that
> will probably be beyond 3.5
Sorry, I mixed up things. If the next release still supports autoconf,
then indeed a reorg is no big deal.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211015/da47e2b4/attachment.sig>
