[gdal-dev] GDAL does not find geometries from KML
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Oct 19 05:53:16 PDT 2021
I tried to convert geometries from a KML file captured with URL https://www.sedecatastro.gob.es/cartografia/fxcc/fxcc_kml.aspx?refcat=0717611VK4701F
Ogrinfo finds layers
INFO: Open of `0717611VK4701F.kml'
using driver `LIBKML' successful.
1: 0717611VK4701F
2: PLANTA GENERAL
3: PLANTA BAJA 00
Ogrinfo finds also a POINT Z geometry from layer 0717611VK4701F. By looking at the KML file with a text editor layers PLANTA GENERAL and PLANTA BAJA 00 both contain one GeometryCollection which is made out of one or several POLYGON Z geometries. However, ogrinfo does not find those geometries. The KML file opens with Google Earth and shows a 3D model of a building. Is there perhaps something special in the structure of this KML?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211019/715c566b/attachment.html>
