[gdal-dev] What's so wrong with this nc file ...
Even Rouault even.rouault at spatialys.com
Wed Oct 20 02:41:01 PDT 2021
See https://github.com/OSGeo/gdal/issues/4581
Le 20/10/2021 à 02:01, Joaquim Manuel Freire Luís a écrit :
> That the geotransform is not detected
> gdalinfo xxx.grd
> Warning 1: dimension #1 (x) is not a Longitude___/X dimension.
> Warning 1: dimension #0 (y) is not a Latitude/Y dimension.
> Driver: netCDF/Network Common Data Format
> Corner Coordinates:
> Upper Left  (    0.0, 0.0)
> Lower Left  (    0.0, 59.0)
> Upper Right (   37.0, 0.0)
> Lower Right (   37.0, 59.0)
> Center      (   18.5, 29.5)
> I can’t get why it’s complaining on “dimension #1 (x) is not a
> Longitude/X dimension.”
> Tried to check the full docs (netcdfdataset.cpp) but not even with a
> debugger I can understand the why.
> Due to it the x,y coordinates are not fished from file, either from
> Julia or from GMT
> NOTE: this works but does not use GDAL
> grdinfo xxx.grd
> xxx.grd: Title: z
> xxx.grd: Command:
> xxx.grd: Remark:
> xxx.grd: Gridline node registration used [Cartesian grid]
> xxx.grd: Grid file format: nf = GMT netCDF format (32-bit float), CF-1.7
> xxx.grd: x_min: 580155 x_max: 581235 x_inc: 30 name: x n_columns: 37
> xxx.grd: y_min: 4416795 y_max: 4418535 y_inc: 30 name: y n_rows: 59
> xxx.grd: v_min: 0.205308780074 v_max: 0.56782335043 name: z
> This DOES NOT WORK (it uses GDAL)
> grdinfo xxx.grd=gd
> xxx.grd: Title: Grid imported via GDAL
> xxx.grd: Command:
> xxx.grd: Remark:
> xxx.grd: Grid file format: gd = Import/export through GDAL
> xxx.grd: x_min: 0.5 x_max: 36.5 x_inc: 1 name: x n_columns: 37
> xxx.grd: y_min: 0.5 y_max: 58.5 y_inc: 1 name: y n_rows: 59
> xxx.grd: scale_factor: 1 add_offset: 0
> +proj=utm +zone=10 +ellps=WGS84 +units=m +no_defs
> What’s so wrong with this nc file? I have others that look similar in
> terms of attributes and things work fine, but for some other cases I
> get the terrible
> Warning 1: dimension #1 (x) is not a Longitude/X dimension.
> and I’m screwed.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211020/5b1377d7/attachment.html>
