[gdal-dev] gdallocationinfo + WCS question...
Even Rouault even.rouault at spatialys.com
Thu Oct 21 13:48:58 PDT 2021
Le 21/10/2021 à 22:32, Rahkonen Jukka (MML) a écrit :
> Hi Even,
> You are right, re-running the request -oo clear_cache gives me the
> same error about 3 bands. Obviously our server was configured right
> when I used it with GDAL last time. Now gdallocationinfo does not work
> even for me because I wiped the working configuration from my cache.
> We will fix the service metadata when we go from beta to official soon.
> The nationalmap.gov service does not still work for me. I cleared the
> cache but I still get a 404 error from the server. Subsets in the
> reques are these
> SUBSET=x(-20037507.0672000013,-13590403.131594259)&SUBSET=y(5303978.1067894027,5304490.1067842878)
The xmin value in the request you get is obviously wrong. The subset I
get with GDAL master and head of 3.3 branch is:
SUBSET=x%(-13591427.131584032,-13590403.131594259)&SUBSET=y(5303978.1067894027,5304490.1067842878)
I suspect you might use a GDAL release version, that hasn't yet received
the following recent fix that is likely related to that issue and will
be in 3.3.3 and 3.4.0:
https://github.com/OSGeo/gdal/commit/8af67b64371c275a3770e75da1bd0d4bb7329295
(I get the same error as you with the 3.2 branch, so I strongly suspect
the above is indeed the fix for that)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211021/ec54e098/attachment.html>
