[gdal-dev] DIMAP driver ignores JP2 world file (J2W)
thomas bonfort thomas.bonfort at gmail.com
Fri Oct 22 02:16:17 PDT 2021
This is mostly likely due to an issue with your dimap. The dimap
driver correctly handles the geotransform for ortho images, or RPCs
for primary images in all cases I have encountered.
regards,
thomas
On Fri, Oct 22, 2021 at 10:31 AM GUIMMARA, Sébastien via gdal-dev
<gdal-dev at lists.osgeo.org> wrote:
> Hello,
> When accessing a DIMAP dataset using the DIMAP driver, the returned GeoTransform has the default values (0 1 0 0 0 1) and the image is incorrectly displayed.
> However, when I access the underlying raster directly (a JP2 file),the JP2ECW driver correctly reads the GeoTransform from the associated world file (.J2W) and the image is correctly displayed.
> Is this a known issue in the DIMAP driver ?
> Sébastien
> The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
> If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
> Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
> All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
