[gdal-dev] gdallocationinfo + WCS question...
Carl Godkin
cgodkin at gmail.com
Mon Oct 25 08:37:21 PDT 2021
I just built GDAL 3.3.3 RC1 here on Windows with VS2019 and PROJ 8.1.1 and
it built easily.
I retried the gdallocationinfo queries that I was having trouble with
beforehand (with 3.3.1) and both the USGS National Map and my local WCS
server queries now return the expected values. I know others had tested
the fix Even mentioned but I wanted to try it myself.
Thanks again for the explanation and the fix,
carl
On Thu, Oct 21, 2021 at 2:00 PM Carl Godkin <cgodkin at gmail.com> wrote:
> Thanks, Even.
> That makes sense. (Finally!) I can wait a little bit to come back to
> this so I'll either build 3.3 HEAD on my own or await the next release.
> It's great that this isn't a random server load thing or something!
> The weird result on my own WCS server also seemed to be caused by a bad
> "xmin" value which is how I started down this road.
> Thanks again,
> carl
> On Thu, Oct 21, 2021 at 1:49 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Le 21/10/2021 à 22:32, Rahkonen Jukka (MML) a écrit :
>> Hi Even,
>> You are right, re-running the request -oo clear_cache gives me the same
>> error about 3 bands. Obviously our server was configured right when I used
>> it with GDAL last time. Now gdallocationinfo does not work even for me
>> because I wiped the working configuration from my cache. We will fix the
>> service metadata when we go from beta to official soon.
>> The nationalmap.gov service does not still work for me. I cleared the
>> cache but I still get a 404 error from the server. Subsets in the reques
>> are these
>> SUBSET=x(-20037507.0672000013,-13590403.131594259)&SUBSET=y(5303978.1067894027,5304490.1067842878)
>> The xmin value in the request you get is obviously wrong. The subset I
>> get with GDAL master and head of 3.3 branch is:
>> SUBSET=x%(-13591427.131584032,-13590403.131594259)&SUBSET=y(5303978.1067894027,5304490.1067842878)
>> I suspect you might use a GDAL release version, that hasn't yet received
>> the following recent fix that is likely related to that issue and will be
>> in 3.3.3 and 3.4.0:
>> https://github.com/OSGeo/gdal/commit/8af67b64371c275a3770e75da1bd0d4bb7329295
>> (I get the same error as you with the 3.2 branch, so I strongly suspect
>> the above is indeed the fix for that)
>> Even
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211025/836890bd/attachment-0001.html>
