[gdal-dev] WCS: Unable to export GeoTIFF files with zero bands
Even Rouault even.rouault at spatialys.com
Mon Oct 25 14:16:01 PDT 2021
Jukka,
The source code was useful to figure out why BandCount was reset to 0 in
the cache :-) So it is related to the fact that there is an extra time
dimension, and such extra dimensions must be specified according to
https://gdal.org/drivers/raster/wcs.html#range-and-dimension-subsetting
Adding   -oo Subset="time(1985-12-31T00:00:00.000Z)" for example solves
the issue
It would be nice to have some warning message though. Might be worth a
ticket
Even
Le 25/10/2021 à 22:51, Rahkonen Jukka (MML) a écrit :
> Hi,
> I do not understand what could be wrong with this WCS. With direct WCS
> 2.0.1 requests everything works fine.
> GetCapabilities:
> https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?service=WCS&AcceptVersions=2.0.1&request=GetCapabilities
> <https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?service=WCS&AcceptVersions=2.0.1&request=GetCapabilities>
> DescribeCoverage:
> https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?service=WCS&version=2.0.1&request=DescribeCoverage&coverageID=ortokuva__ortokuva
> <https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?service=WCS&version=2.0.1&request=DescribeCoverage&coverageID=ortokuva__ortokuva>
> This is listing DataRecord with three fields: red band, green band,
> and blue band.
> GetCoverage:
> https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?service=WCS&version=2.0.1&request=GetCoverage&CoverageID=ortokuva__ortokuva&SUBSET=E(393450,393650)&SUBSET=N(7495450,7495650)&format=image/tiff
> <https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?service=WCS&version=2.0.1&request=GetCoverage&CoverageID=ortokuva__ortokuva&SUBSET=E(393450,393650)&SUBSET=N(7495450,7495650)&format=image/tiff>
> This sends a tiff file.
> With GDAL:
> gdalinfo -oo CLEAR_CACHE
> "WCS:https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?"
> I get the subdatasets.
> gdalinfo
> "WCS:https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?version=2.0.1&coverage=ortokuva__ortokuva"
> Looks good but I am not sure what I should expect to see.
> gdal_translate -projwin 393450 7495650 393650 7495450
> wcs.tif
> This gives an error:
> Input file size is 1348357, 2316500
> ERROR 1: wcs.tif: Unable to export GeoTIFF files with zero bands.
> I can indeed see at the end of the automatically generated XML file
> that the band count is interpreted to be zero:
> <Domain>E,N</Domain>
> <Low>61254.6580619824,6623749.72946716</Low>
> <High>735433.573091962,7782000.0</High>
> <GridAxes>i,j</GridAxes>
> <NoDataValue>,,</NoDataValue>
> <BandCount>0</BandCount>
> <Format>image/tiff</Format>
> I tried to edit the band count into 3 by hand, but GDAL is changing it
> back to zero.
> The example from the WCS driver page
> <https://gdal.org/drivers/raster/wcs.html> that  is using the very
> same server and coverage does save an image even there is no
> fundamental difference in the command.
> gdal_translate -oo CACHE=wcs_cache -oo CLEAR_CACHE -oo
> INTERLEAVE=PIXEL -projwin 377418 6683393.87938218 377717.879386966
> 6683094 -oo Subset="time(1985-01-01T00:00:00.000Z)" -outsize 60 0
> scaled.tiff
> I am using GDAL version is 3.4.0dev from yesterday.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211025/0089510d/attachment.html>
