[gdal-dev] Python error in me or in gisinternals.com packages?
Even Rouault
even.rouault at spatialys.com
Tue Oct 26 09:45:57 PDT 2021
Hi Jukka,
I just checked and indeed gisinternals uses SWIG 2 to generate python
bindings, which is not Python 3 compatible. I've added a comment in
https://github.com/gisinternals/buildsystem/issues/180#issuecomment-952121822
about that
Even
Le 26/10/2021 à 18:15, Rahkonen Jukka (MML) a écrit :
> Hi,
> I can use GDAL Python bindings from OSGeo4W installation but folks in
> gis.stackexchange have problems with the gistinternals.com binaries so
> I had a try too. I installed
> * python-3.7.9-amd64
> * gdal-303-1928-x64-core MIS installer from gisinternals
> * GDAL-3.3.2.win-amd64-py3.7 MSI installer from gisinternals
> Now I have all from above and I have adjusted paths a bit and I can
> get this far:
> * Python 3.7.9 starts
> * I can load osr with “from osgeo import osr”
> But if I try “from osgeo import ogr” I get:
> Traceback (most recent call last):
> File “<stdin>”, line 1, in <module>
> File “c:/Program Files\Python37\lib\site-packages\osgeo\ogr.py”,
> line 245, in <module>
> import osr
> ModuleNotFoundError: No module named ‘osr’
> Same thing with “from osgeo import gdal” but this time the error in on
> line 1931 in gdal.py and missing module is ‘ogr’.
> Do the errors mean that the Python stuff is using deprecated “import
> osr” and “import ogr” while they should have it as “import osgeo.osr”
> and “import osgeo.ogr” as they seem to stand in the working OSGeo4W
> installation? I do not have rights to edit the files, and they have
> also this warning in the beginning:
> # This file was automatically generated by SWIG (http://www.swig.org
> <http://www.swig.org>).
> # Version 4.0.2
> # Do not make changes to this file unless you know what you are
> doing--modify
> # the SWIG interface file instead.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211026/1a147a23/attachment.html>
