[gdal-dev] test failures on pkgsrc build of 3.3.2rc3
Greg Troxel
gdt at lexort.com
Fri Sep 3 17:28:08 PDT 2021
Even Rouault <even.rouault at spatialys.com> writes:
>> FAILED gdrivers/eedai.py::test_eedai_GOOGLE_APPLICATION_CREDENTIALS - assert ...
> Not sure what happens here. Probably some harden configuration of
> openssl that rejects the private key ? Apparently it fails on Mac too
> from
> https://github.com/OSGeo/gdal/commit/7816b68130cc7a79e5477a47dc6eb0227f2ae47d
This is pure speculation, but I see in the code:
gdal.FileFromMemBuffer('/vsimem/my.json', """{
"private_key":"-----BEGIN PRIVATE KEY-----
an I wonder if this file (in some VFS?) has an associated mode? I would
sort of expect openssl to error if the private key file were readable by
group or other, and I don't understand this filefromstring big. (I get
the concept; I just have no idea how it works.)
This may or may not be a more detailed run log:
============================= test session starts ==============================
platform netbsd9 -- Python 3.8.11, pytest-6.2.4, py-1.10.0, pluggy-0.13.1
rootdir: /home/n0/gdt/SOFTWARE/GEO/GDAL/gdal/autotest, configfile: pytest.ini
plugins: sugar-0.9.4, env-0.6.2
collected 9 items
gdrivers/eedai.py ...Fs...s [100%]
=================================== FAILURES ===================================
__________________ test_eedai_GOOGLE_APPLICATION_CREDENTIALS ___________________
def test_eedai_GOOGLE_APPLICATION_CREDENTIALS():
if gdaltest.eedai_drv is None:
pytest.skip()
MIICeAIBADANBgkqhkiG9w0BAQEFAASCAmIwggJeAgEAAoGBAOlwJQLLDG1HeLrk\n
VNcFR5Qptto/rJE5emRuy0YmkVINT4uHb1be7OOo44C2Ev8QPVtNHHS2XwCY5gTm\n
i2RfIBLv+VDMoVQPqqE0LHb0WeqGmM5V1tHbmVnIkCcKMn3HpK30grccuBc472LQ\n
DVkkGqIiGu0qLAQ89JP/r0LWWySRAgMBAAECgYAWjsS00WRBByAOh1P/dz4kfidy\n
TabiXbiLDf3MqJtwX2Lpa8wBjAc+NKrPXEjXpv0W3ou6Z4kkqKHJpXGg4GRb4N5I\n
2FA+7T1lA0FCXa7dT2jvgJLgpBepJu5b//tqFqORb4A4gMZw0CiPN3sUsWsSw5Hd\n
DrRXwp6sarzG77kvZQJBAPgysAmmXIIp9j1hrFSkctk4GPkOzZ3bxKt2Nl4GFrb+\n
bpKSon6OIhP1edrxTz1SMD1k5FiAAVUrMDKSarbh5osCQQDwxq4Tvf/HiYz79JBg\n
Wz5D51ySkbg01dOVgFW3eaYAdB6ta/o4vpHhnbrfl6VO9oUb3QR4hcrruwnDHsw3\n
4mDTAkEA9FPZjbZSTOSH/cbgAXbdhE4/7zWOXj7Q7UVyob52r+/p46osAk9i5qj5\n
Kvnv2lrFGDrwutpP9YqNaMtP9/aLnwJBALLWf9n+GAv3qRZD0zEe1KLPKD1dqvrj\n
j+LNjd1Xp+tSVK7vMs4PDoAMDg+hrZF3HetSQM3cYpqxNFEPgRRJOy0CQQDQlZHI\n
yzpSgEiyx8O3EK1iTidvnLXbtWabvjZFfIE/0OhfBmN225MtKG3YLV2HoUvpajLq\n
gwE6fxOLyJDxuWRf\n
-----END PRIVATE KEY-----",
"client_email":"my at email.com"
gdal.SetConfigOption('EEDA_URL', '/vsimem/ee/')
gdal.SetConfigOption('GOOGLE_APPLICATION_CREDENTIALS', '/vsimem/my.json')
gdal.SetConfigOption('EEDA_PRIVATE_KEY', None)
gdal.SetConfigOption('EEDA_CLIENT_EMAIL', None)
gdal.SetConfigOption('GO2A_AUD', '/vsimem/oauth2/v4/token')
gdal.SetConfigOption('GOA2_NOW', '123456')
gdal.FileFromMemBuffer('/vsimem/oauth2/v4/token&POSTFIELDS=grant_type=urn%3Aietf%3Aparams%3Aoauth%3Agrant-type%3Ajwt-bearer&assertion=eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiAibXlAZW1haWwuY29tIiwgInNjb3BlIjogImh0dHBzOi8vd3d3Lmdvb2dsZWFwaXMuY29tL2F1dGgvZWFydGhlbmdpbmUucmVhZG9ubHkiLCAiYXVkIjogIi92c2ltZW0vb2F1dGgyL3Y0L3Rva2VuIiwgImlhdCI6IDEyMzQ1NiwgImV4cCI6IDEyNzA1Nn0%3D.1W564xcQESVsqZmBEIMzj4rr0RuGa4RiUPZp5H%2FNENN9V9oPSTdacw%2BMiu3pcFf9AJv8wj0ajUeRsgTmvSicAftER49xeCQYUrs6uV122FGVsxml26kMFacNsCgRad%2Fy7xCAhMPfRJsqxS2%2BB392ssBeEzTGCSI6W3AsJg64OfA%3D',
'{ "access_token": "my_token", "token_type": "Bearer", "expires_in": 3600 }')
ds = gdal.Open('EEDAI:image')
gdal.Unlink('/vsimem/my.json')
gdal.SetConfigOption('EEDA_URL', None)
gdal.SetConfigOption('GOOGLE_APPLICATION_CREDENTIALS', None)
if gdal.GetLastErrorMsg().find('CPLRSASHA256Sign() not implemented') >= 0:
pytest.skip()
if ds is None and gdaltest.is_github_workflow_mac():
print(gdal.GetLastErrorMsg())
pytest.xfail('Failure. See https://github.com/rouault/gdal/runs/1329425333?check_suite_focus=true')
> assert ds is not None
E assert None is not None
/home/n0/gdt/SOFTWARE/GEO/GDAL/gdal/autotest/gdrivers/eedai.py:439: AssertionError
----------------------------- Captured stderr call -----------------------------
ERROR 1: PEM_read_bio_PrivateKey() failed
=========================== short test summary info ============================
==================== 1 failed, 6 passed, 2 skipped in 0.59s ====================
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210903/497e716b/attachment.sig>
