[gdal-dev] Motion: promote GDAL 3.3.2 RC3
Even Rouault
even.rouault at spatialys.com
Mon Sep 6 10:30:14 PDT 2021
Hi Sean,
did you manage to adapt rasterio / can we promote the release ?
Even
Le 02/09/2021 à 17:21, Even Rouault a écrit :
> Hi Sean,
> sure we can delay a bit the release of the final tarballs. Anyway as
> we have the minimum 2 business day rule to pass a motion, this won't
> be before Monday. Those issues with axis order seem to be a never
> ending source of annoyance. Were existing before I got into the
> geo-business and will probably be still there when I retire...
> I didn't anticipate that change to break rasterio, although those type
> of changes tend to have tricky consequences, but at the same time
> having AutoIdentifyEPSG() putting EPSG:4326 on a CRS with "wrong" axis
> order caused other issues.
> Even
> Le 02/09/2021 à 17:19, Sean Gillies a écrit :
>> Oops, forgot to reply to the list. Also, to be more specific, could
>> we hold 3.3.2 until Monday, September 6?
>> On Thu, Sep 2, 2021 at 9:10 AM Sean Gillies <sean at mapbox.com
>> <mailto:sean at mapbox.com>> wrote:
>> I wish I'd noticed the change around EPSG:4326 sooner. I didn't
>> see a particular announcement, but the breakage was obvious in
>> rasterio's CI builds with GDAL master and I should have been
>> watching more closely.
>> If people update GDAL to 3.3.2 they may break their applications
>> that use rasterio. We'll probably be able to get a new version
>> out by the end of the week or beginning of next week. Could we
>> hold the release a few more days?
>> On Thu, Sep 2, 2021 at 12:54 AM Even Rouault
>> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>>
>> wrote:
>> Hi,
>> Having heard no issues being reported regarding RC3
>> Motion:
>> Adopt GDAL 3.3.2 RC3 as final 3.3.2 release
>> Starting with my +1
>> Even
>> Sean Gillies
>> Sean Gillies
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210906/7c79fbaf/attachment.html>
