[gdal-dev] Handling NetCDF using UGRID Convention
Even Rouault
even.rouault at spatialys.com
Wed Sep 8 14:31:23 PDT 2021
no the GDAL raster driver has no support for the UGRIB convention. You
could likely use the multidimensional API
(https://gdal.org/user/multidim_raster_data_model.html) and tools to
access such files at a lower level, but you'd probably be better uses
MDAL which has apparently a UGRIB reader:
https://www.mdal.xyz/drivers/ugrid.html and should be able to expose meshes.
Even
Le 08/09/2021 à 22:21, Laframboise,Felix (ECCC) a écrit :
> Hi,
> I am currently using GDAL 3.1.3 on a Ubuntu machine. I am trying to
> work with NetCDF files using the UGRID convention (described here:
> https://ugrid-conventions.github.io/ugrid-conventions/
> <https://ugrid-conventions.github.io/ugrid-conventions/>).
> I am having difficulty working with this kind of NetCDF file. Here is
> the output of `gdalinfo` against one subdataset of a NetCDF file
> using the UGRID convention.
> `$ gdalinfo -mm -proj4
> NETCDF:"PATH_TO_NETCDF/CMC_shop_slfeav200n_surface_sfc_0_2019080706_P040.nc":St_Lawrence_River_face_nodes
> Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
> Driver: netCDF/Network Common Data Format
> Files: PATH_TO_NETCDF/CMC_shop_slfeav200n_surface_sfc_0_2019080706_P040.nc
> Size is 3, 87396
> Metadata:
> St_Lawrence_River_face_nodes#cf_role=face_node_connectivity
> St_Lawrence_River_face_nodes#long_name=Maps every triangular face to
> its three corner nodes.
> St_Lawrence_River_face_nodes#start_index=0
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0,87396.0)
> Upper Right ( 3.0, 0.0)
> Lower Right ( 3.0,87396.0)
> Center ( 1.5,43698.0)
> Band 1 Block=3x1 Type=Int32, ColorInterp=Undefined
> Computed Min/Max=0.000,53331.000
> NoData Value=-2147483647
> Metadata:
> long_name=Maps every triangular face to its three corner nodes.
> NETCDF_VARNAME=St_Lawrence_River_face_nodes
> start_index=0
> Following this output, I can confirm that the size and the extent
> (Corner Coordinates) are not right for example.
> Is there anyone who has worked with NetCDF files using the UGRID
> convention? Is GDAL capable of handling or manipulating this kind of
> NetCDF file?
> Thanks a lot in advance for your answer(s)!
> Félix Laframboise
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210908/bcdb63e4/attachment.html>
