[gdal-dev] GDAL installation on Docker not working anymore
Even Rouault even.rouault at spatialys.com
Thu Sep 23 09:56:48 PDT 2021
Perhaps related to https://github.com/OSGeo/gdal/issues/4467 ? where
upgrading setuptools was suggested
Le 23/09/2021 à 18:40, Matheus Cammarosano Hidalgo a écrit :
> I made a Dockerfile two years ago with a GDAL 2.2.3 install that was
> working fine ultil three weeks ago, when I made a change in my Python
> code (not Dockerfile), but when I tried to build the image I got an
> error installing GDAL.
> I am using a python:3.7 default image from Docker and I have the
> following lines to install GDAL:
> # Install GDAL dependencies
> RUN apt-get install -y python3-pip libgdal-dev locales
> # Ensure locales configured correctly
> RUN locale-gen en_US.UTF-8
> ENV LC_ALL='en_US.utf8'
> # Set python aliases for python3
> RUN echo 'alias python=python3' >> ~/.bashrc
> RUN echo 'alias pip=pip3' >> ~/.bashrc
> # Update C env vars so compiler can find gdal
> ENV CPLUS_INCLUDE_PATH=/usr/include/gdal
> ENV C_INCLUDE_PATH=/usr/include/gdal
> RUN pip3 install GDAL==2.2.3
> When I try to build the image, I get the following error message:
> ERROR: Command errored out with exit status 1: /usr/local/bin/python
> -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] =
> '"'"'/tmp/pip-install-9sbmiien/gdal_b1debd2d108d43f38c9919e931126904/setup.py'"'"';
> __file__='"'"'/tmp/pip-install-9sbmiien/gdal_b1debd2d108d43f38c9919e931126904/setup.py'"'"';f
> = getattr(tokenize, '"'"'open'"'"', open)(__file__) if
> os.path.exists(__file__) else io.StringIO('"'"'from setuptools import
> setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"',
> '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))'
> install --record /tmp/pip-record-sp2ip9vm/install-record.txt
> --single-version-externally-managed --compile --install-headers
> /usr/local/include/python3.7m/GDAL Check the logs for full command output.
> Does anyone know what is happening and some way to make the
> installation work? Thank you!
> Best regards,
> Matheus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210923/a851ec9b/attachment.html>
