[gdal-dev] ISCE raster changes from BIL to BIP after gdal_translate
Scott Staniewicz
scott.stanie at gmail.com
Thu Sep 23 16:45:56 PDT 2021
I've got a 2 band, band-interleaved-line file gendered from the ISCE
software. I was doing some subsetting of it with gdal_translate, and I
noticed that the format got changed to BIP:
$ ls
20130719_20150427.unw 20130719_20150427.unw.vrt 20130719_20150427.unw.xml
$ grep -i -n3 scheme 20130719_20150427.unw.xml
96- <value>2</value>
97- <doc>Number of image bands.</doc>
98- </property>
99: <property name="scheme">
100- <value>BIL</value>
101: <doc>Interleaving scheme of the image.</doc>
102- </property>
103- <property name="width">
104- <value>586</value>
After running gdal_translate, the format has changed to BIP:
$ gdal_translate 20130719_20150427.unw test.unw -of ISCE
Input file size is 586, 882
0...10...20...30...40...50...60...70...80...90...100 - done.
(mapping) [scott at grace gdal-translate-bug]$ grep -i -n3 scheme test.unw.xml
11- <property name="DATA_TYPE">
12- <value>FLOAT</value>
13- </property>
14: <property name="SCHEME">
15- <value>BIP</value>
16- </property>
17- <property name="BYTE_ORDER">
I'm assuming it's related to this line for creating a dataset with default
BIP:
https://github.com/OSGeo/gdal/blob/master/gdal/frmts/raw/iscedataset.cpp#L839
But I'm not familiar enough with the gdal_translate code to know where the
options are getting generated and passed here.
Any advice on where might be a good place to fix the ISCE raster generation?
Thanks,
Scott
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210923/d0db06e0/attachment.html>
