[gdal-dev] Enabling default compression for COG ?
Even Rouault
even.rouault at spatialys.com
Thu Sep 30 06:46:02 PDT 2021
should we enable a default compression scheme for the COG driver ? I've
heard people "complaining" about that, or people just not realizing that
specifying a compression method was something reasonable to do. Likely a
lossless one to be conservative. ZSTD is probably not reasonable as it's
too non-standard outside of the GDAL/libtiff world. So the choice would
go basically between LZW or DEFLATE. LZW has probably the best
compatibility profile (but the less efficient). I guess that most
browser based solutions would handle it ? Thoughts ?
Even
http://www.spatialys.com
