[gdal-dev] Enabling default compression for COG ?
Patrick Young
patrick.mckendree.young at gmail.com
Thu Sep 30 07:39:29 PDT 2021
Another option would be to emit a warning/suggestion when left unset. An
added benefit would be that folks possibly self discover that they can
control the compression scheme.
P
On Thu, Sep 30, 2021, 7:53 AM Vincent Sarago <vincent.sarago at gmail.com>
wrote:
> +1
> I think it’s reasonable to have a default compression. In rio-cogeo I’ve
> set the default to `DEFLATE` but that’s was a personal preference.
> Vincent
> > On Sep 30, 2021, at 3:46 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Hi,
> > should we enable a default compression scheme for the COG driver ? I've
> heard people "complaining" about that, or people just not realizing that
> specifying a compression method was something reasonable to do. Likely a
> lossless one to be conservative. ZSTD is probably not reasonable as it's
> too non-standard outside of the GDAL/libtiff world. So the choice would go
> basically between LZW or DEFLATE. LZW has probably the best compatibility
> profile (but the less efficient). I guess that most browser based solutions
> would handle it ? Thoughts ?
> > Even
> > http://www.spatialys.com
> > My software is free, but my time generally not.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210930/a603dea0/attachment.html>
