[gdal-dev] Memory allocation issues on Android 11+ and scudo
Andrew C Aitchison
andrew at aitchison.me.uk
Sat Apr 2 04:09:57 PDT 2022
On Sat, 2 Apr 2022, Philippe Lelong wrote:
> Hi again,
> Still fighting with that one.>
> I have tried to not run gdal multithreaded, same issue. I have also
> tried to replace malloc(nSize) with calloc(1, nSize) in VSIMalloc to
> make sure the memory is initialized, same issue. And many other
> things... still crashing.
> I don't know how to interpret the logs I joined in the previous mail
> with VSIMalloc etc debugging, do you see anything special in them?
> Any other idea I can try to isolate the problem?
Is valgrind an option, or would that replace the problem memory library ?
I believe that valgrind is not the only memory debugger.
The "swap is low" message
> 03-28 21:02:14.511 583 583 I lmkd : Reclaim 'android.process.acore' (27861), uid 10071, oom_score_adj 850, state 99 to free 33916kB rss, 56816kB swap; reason: low watermark is breached and swap is low (1848484kB < 838860kB)
is intriguing - to me it suggests a 32bit sign issue
1 848 484 kB <
838 860 kB
Could there be a 32/64bit library mismatch ?
Andrew C. Aitchison Kendal, UK
