[gdal-dev] HAVE_XLOCALE_H -vs- GDAL_HAVE_XLOCALE_H
Even Rouault
even.rouault at spatialys.com
Wed Apr 6 10:08:32 PDT 2022
Javier,
could you rename GDAL_HAVE_XLOCALE_H to HAVE_XLOCALE_H, at the minimum
in the places where it is used in
https://github.com/OSGeo/gdal/commit/d83a9f58acb and
https://github.com/OSGeo/gdal/commit/ab9386760f60e6a312d8418737b5fd94dd7adccb.
(I don't think it must be used elsewhere)
As far as I remember the reason for the GDAL_ prefix was to avoid
"contamination" for other software that use cpl_config.h, but since then
I've restructured that file so that most of it is only defined when
building GDAL, and not when including GDAL, so that GDAL_ prefix is no
longer useful
Even
Le 06/04/2022 à 18:38, Javier Jimenez Shaw a écrit :
> Hi
> I have seen these two macros defined in the code, and maybe there is a
> conflict.
> in "cmake/template/cpl_config.h.in <http://cpl_config.h.in>" it says
> /* Define to 1 if you have the <xlocale.h> header file. */
> #cmakedefine GDAL_HAVE_XLOCALE_H 1
> and "cmake/helpers/configure.cmake"
> check_include_file("xlocale.h" GDAL_HAVE_XLOCALE_H)
> but in "ogr/ogrsf_frmts/geojson/libjson/json_tokener.c" says
> #ifdef HAVE_XLOCALE_H
> #include <xlocale.h>
> #endif
> (that is failing in my M1 compilation)
> Should it be
> #if defined(HAVE_XLOCALE_H) || defined(GDAL_HAVE_XLOCALE_H)
> or directly
> #ifdef GDAL_HAVE_XLOCALE_H
> or something else?
> I can do such a PR.
> BTW, there are multiple "HAVE_*" macros, why is this one "GDAL_HAVE_*"?
> Thanks.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220406/a094bc39/attachment.html>
