[gdal-dev] GetProjectionRef returns invalid projection
Frank Hübenthal
huebenthal at uxis.de
Fri Apr 15 04:52:54 PDT 2022
Here it is: https://easyupload.io/rg2ltd
Unfortunately It is rather big (36MB).
Best regards,
Frank
Am 15.04.2022 um 13:41 schrieb Even Rouault:
> Frank,
> please provide a link to such file
> Even
> Le 15/04/2022 à 13:27, Frank Hübenthal a écrit :
>> I use GDAL C++ to load GeoTIFF files. Since I moved to GDAL 3.4 I
>> have problems to get the projection string from some (not all) of
>> these GeoTIFF files. With GDAL 3.2 still something like this was
>> returned:
>> PROJCS["WGS 84 / Pseudo-Mercator",GEOGCS["WGS
>> 84",DATUM["WGS_1984",SPHEROID["WGS
>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Mercator_1SP"],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],EXTENSION["PROJ4","+proj=merc
>> +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +k=1 +units=m
>> +nadgrids=@null +wktext +no_defs"],AUTHORITY["EPSG","3857"]]
>> With GDAL 3.4 I get for the same map file only this:
>> "LOCAL_CS["WGS 84 /
>> Pseudo-Mercator",UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","3857"]]"
>> I use the projection to create finally a transformation, but
>> OGRCreateCoordinateTransformation returns NULL with the short string
>> from GDAL 3.4 while it was still working with 3.2.
>> Best regards,
>> Frank
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
