[gdal-dev] GetProjectionRef returns invalid projection
Frank Hübenthal huebenthal at uxis.de
Fri Apr 15 05:24:44 PDT 2022
Perfect. This works.
Thank you,
Frank
Am 15.04.2022 um 14:08 schrieb Even Rouault:
> Tihs works fine for me:
> $ python -c "from osgeo import gdal; ds=
> gdal.Open('/home/even/Téléchargements/OFM.tif');
> print(ds.GetProjectionRef())"
> PROJCS["WGS 84 / Pseudo-Mercator",GEOGCS["WGS
> 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Mercator_1SP"],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],EXTENSION["PROJ4","+proj=merc
> +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +k=1 +units=m
> +nadgrids=@null +wktext +no_defs"],AUTHORITY["EPSG","3857"]]
> However I suspect that your issue is that PROJ is misconfigured and
> cannot find its proj.db. Make sure that PROJ_LIB points to the
> directory where proj.db is located
> I can reproduce your issue by setting a wrong path for PROJ_LIB:
> $ PROJ_LIB=/unexisting/path python -c "from osgeo import gdal; ds=
> Warning 1: PROJ: proj_create_from_database: Cannot find proj.db
> Warning 1: The definition of projected CRS EPSG:3857 got from GeoTIFF
> keys is not the same as the one from the EPSG registry, which may
> cause issues during reprojection operations. Set GTIFF_SRS_SOURCE
> configuration option to EPSG to use official parameters (overriding
> the ones from GeoTIFF keys), or to GEOKEYS to use custom values from
> GeoTIFF keys and drop the EPSG code.
> LOCAL_CS["WGS 84 /
> Pseudo-Mercator",UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH]]
> Le 15/04/2022 à 13:52, Frank Hübenthal a écrit :
>> Here it is: https://easyupload.io/rg2ltd
>> Unfortunately It is rather big (36MB).
>> Best regards,
>> Frank
>> Am 15.04.2022 um 13:41 schrieb Even Rouault:
>>> Frank,
>>> please provide a link to such file
>>> Even
>>> Le 15/04/2022 à 13:27, Frank Hübenthal a écrit :
>>>> I use GDAL C++ to load GeoTIFF files. Since I moved to GDAL 3.4 I
>>>> have problems to get the projection string from some (not all) of
>>>> these GeoTIFF files. With GDAL 3.2 still something like this was
>>>> returned:
>>>> +units=m +nadgrids=@null +wktext +no_defs"],AUTHORITY["EPSG","3857"]]
>>>> With GDAL 3.4 I get for the same map file only this:
>>>> "LOCAL_CS["WGS 84 /
>>>> Pseudo-Mercator",UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","3857"]]"
>>>> I use the projection to create finally a transformation, but
>>>> OGRCreateCoordinateTransformation returns NULL with the short
>>>> string from GDAL 3.4 while it was still working with 3.2.
>>>> Best regards,
>>>> Frank
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
