[gdal-dev] Using a custom operation with osr.CoordinateTransformation
Stefano Iacovella
stefano.iacovella at gmail.com
Tue Apr 19 04:32:32 PDT 2022
Both examples look like what I was looking for
Thanks a lot Even :)
Stefano
Il giorno mar 19 apr 2022 alle ore 12:17 Even Rouault <
even.rouault at spatialys.com> ha scritto:
> Hi,
> looking at
> https://github.com/OSGeo/PROJ/blob/master/data/sql/other_transformation_custom.sql
> should give you good hints on how to add custom transformations, here
> under a PROJ authority
> If you want to create your own authority, you'll also need to do similar
> steps as the ones dones for the NKG authority in
> https://github.com/OSGeo/PROJ/blob/master/data/sql/nkg_post_customizations.sql
> Even
> Le 19/04/2022 à 08:55, Stefano Iacovella a écrit :
> > Dear all,
> > I am wondering which is the best approach to use a custom operation to
> > transform coordinates from a datum to another.
> > I have managed to use a custom operation by creating a specific
> > pipeline and set it as:
> > options = osr.CoordinateTransformationOptions()
> > options.SetOperation('''+proj=pipeline
> > +step +proj=axisswap +order=2,1
> > +step +proj=unitconvert +xy_in=deg +xy_out=rad
> > +step +proj=push +v_3
> > +step +proj=cart +ellps=intl
> > +step +proj=helmert +x=-104.1 +y=-49.1 +z=-9.9
> > +rx=0.971 +ry=-2.917 +rz=0.714 +s=-11.68 +convention=position_vector
> > +step +inv +proj=cart +ellps=WGS84
> > +step +proj=pop +v_3
> > +xy_in=rad
> > +xy_out=deg
> > +step +proj=axisswap +order=2,1''')
> > transform = osr.CoordinateTransformation(source_crs, target_crs, options)
> > I have a few custom operation, then I would like to understand if it
> > is possible to include their definitions in the PROJ configuration,
> > with a different autorithy then EPSG. So that I can use it in
> > something similar to:
> options.SetOperation('urn:ogc:def:coordinateOperation:my_authority::900001')
> > I tried to read documentation of GDAl and PROJ but didn't find,
> > probably my fault, any clear explanation on how to customize
> > configuration to include custom operation.
> > Thank you all in advance for any hint
> > Stefano
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220419/ccc75542/attachment.html>
