[gdal-dev] Issues in Raster Resampling
Even Rouault
even.rouault at spatialys.com
Sat Apr 23 02:13:23 PDT 2022
Mike,
if you look at the nodata value set on 2015_daytime_mean_clip.tif, it is
at 3.39999995214436425e+38, and not at nan.
If you add the srcNodata=math.nan argument to gdal.Warp(), this will fix
your issue.
Even
Le 23/04/2022 à 06:40, Chao Li a écrit :
> Dear Gdal Developer,
> Thank you for reading my email.
> I used gdal.Wrap() to resample from a high resolution to a lower.
> However, my raster has no value (nan). So, when I set resampleAlg, the
> larger grids with nan(s) will become nan.
> Here is my reprex in Python:
> from osgeo import gdal
> ### resample and reproject
> ### data are from MOD11A2 and MYD11A2, and have been converted into
> annual mean values
> raster_rprj = gdal.Warp("./2015_daytime_mean_re.tif",
> "./2015_daytime_mean_clip.tif", dstSRS =
> "EPSG:4326",
> xRes = 0.008, yRes = 0.008, resampleAlg =
> "average")
> raster_rprj = None
> I hope it runs as the function np.nanmean()
> Thank you for your time.
> Best regards,
> Mike Li
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
