[gdal-dev] default for RelativeToVRT field
Even Rouault
even.rouault at spatialys.com
Sat Apr 23 02:37:44 PDT 2022
Michael,
> Or is it just a matter of forcing an input path to be absolute?
for regular use cases (ie VRT name not set to empty), you might not even
been able to do that in master since
https://github.com/OSGeo/gdal/commit/6d7001656d06af138f8e46ff1651056626db11e8
which tries to write relative filename as much as possible, even if all
paths are absolute
Testing with your use case with empty VRT filename, I see the behavior
has not changed, and that you'll indeed get relativeToVRT="0" only if
using a source dataset with an absolute path. For most use cases where
you use an empty filename, it doesn't matter much because you don't
actually re-open it and use it immediately, and thus the source dataset
is not re-opened. I can imagine though that you could get into trouble
if serializing it from the xml:VRT content and re-opening the resulting VRT.
> Is it possible to force GDAL to make the SourceFilename absolute by
> setting options?
The solution would probably be to add an explicit creation option to the
VRT driver, like SOURCE_PATH=ABSOLUTE, that would override the current
heuristics.
Even
http://www.spatialys.com
