[gdal-dev] how to build gdal 3.4.2
Kavitha K
kmskavi at gmail.com
Mon Apr 25 23:28:12 PDT 2022
Hi All,
I have downloaded gdal-3.4.2
cd gdal-3.4.2
./configure
checking for internal_proj_create_from_wkt in -linternalproj... no
configure: error: PROJ 6 symbols not found
[root at pi-dnac-158 proj-6.0.0]# ./configure --prefix /usr/local
checking for pkg-config... /bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for SQLITE3... configure: error: Package requirements (sqlite3 >=
3.7) were not met:
No package 'sqlite3' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables SQLITE3_CFLAGS
and SQLITE3_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
thanks,
Kavitha
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220426/4193f823/attachment.html>
