[gdal-dev] Convert to min containing bit depth?
Matt.Wilkie at yukon.ca
Tue Apr 26 09:47:04 PDT 2022
Thank you both for this, very helpful.
-Matt
Sent: April 21, 2022 11:18 PM
To: Mike Taves <mwtoews at gmail.com>
Cc: Matt.Wilkie <Matt.Wilkie at yukon.ca>; gdal dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Convert to min containing bit depth?
Computing the min value is also requited if you have negative values and could also be useful If you wanted to optimize that method further by utilising the offset parameter (and or the scale, but computing the right combination for an optimize lossless compression could be more expensive).
On Fri, 22 Apr 2022, 06:05 Mike Taves, <mwtoews at gmail.com<mailto:mwtoews at gmail.com>> wrote:
On Fri, 22 Apr 2022 at 07:05, <Matt.Wilkie at yukon.ca<mailto:Matt.Wilkie at yukon.ca>> wrote:
> Idea for a small but useful python tool: scan image for min/max values and convert to smallest possible bit depth without losing values. Surely someone has done something like this already. Any suggestions for where to look for prior art?
This is driver-specific, as certain formats expect multiples of 2
(e.g.) NBITS=1/2/4. But for GTiff, what I typically use in a script is
to find the maximum value, then use "ceil(log(maxval, 2))" to get the
number of bits, e.g.:
from math import ceil, log
from osgeo import gdal
maxval = 17 # for example
nbits = ceil(log(maxval, 2)) # 5
drv = gdal.GetDriverByName("GTiff")
opts = [f"NBITS={maxval}"]
ds = drv.Create(fname, nx, ny, 1, gdal.GDT_Byte, opts)
similar can be done with rasterio, passing the keyword
"rasterio.open(fname, 'w', ..., nbits=nbits)"
For the drivers that expect NBITS as a multiple of 2:
nbits = 2**ceil(log(nbits, 2))
If nbits is greater than 8, then UInt16 or UInt32 may be required, as
supported by the driver.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-d<https://can01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=05%7C01%7CMatt.Wilkie%40yukon.ca%7C530d4395252944fbff3a08da2427e83d%7C98f515313973490abb70195aa264a2bc%7C0%7C0%7C637862051196803406%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Wxzbgz3TEIvRtrCiUvFSGc5CUoGIbeeCC8VXt1wtfuA%3D&reserved=0>e vroom
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220426/5c65b868/attachment.html>
