[gdal-dev] Moving GDAL GRASS driver in a dedicated repository ?
Markus Neteler
neteler at osgeo.org
Thu Apr 28 13:31:07 PDT 2022
Hi Even,
(back to your wish)
On Thu, Nov 18, 2021 at 7:12 PM Even Rouault <even.rouault at spatialys.com> wrote:
> Hi,
> (writing to both GDAL and GRASS lists)
> Working on the transition to CMake as the GDAL build system, the
> particular status of the GRASS driver in GDAL raised my attention.
> (The following is based on my understanding. It has been ages since I
> didn't try this...)
> This driver is a bit odd in the sense that there's a cyclic dependency
> to work around, as GRASS links to GDAL , but the GDAL GRASS driver needs
> to be linked against GRASS.
> So the usual procedure is:
> - build GDAL without the GRASS driver
> - build GRASS against GDAL
> - build the GDAL GRASS driver from the separate gdal-grass tarball that
> GDAL distributes along its main tarball.
> With the current GDAL autoconf build system, there's also the
> possibility to rebuild GDAL with the GRASS driver builtin in libgdal,
> but that's a bit odd, since you need to make sure that this new libgdal
> is the one that GRASS will link against at runtime, otherwise chaos will
> ensure. I'm not sure if that's used. This is typically something I would
> *not* want to support in the new GDAL cmake build.
> All in all, given the particular nature of that driver, I believe it
> would be better in a dedicated repository, with its standalone build
> scripts, whose initial version could be just the ones of
> https://github.com/OSGeo/gdal/tree/master/frmts/grass/pkg, or evolve to
> CMake or whatever the maintainers of that driver would prefer. I believe
> this would make the situation clearer.
> Opinions ? and people interested in setting up that dedicated repository ?
Yes and finally done that:
https://github.com/OSGeo/gdal-grass
Hope I got it right (history is preserved, I used
git filter-repo --path ogr/ogrsf_frmts/grass --path frmts/grass
and then moved the remaining needed files into the toplevel directory.
Hope I got it right.
Markus
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
