[gdal-dev] How to read a PGeo source file using GDAL 2.4
andy
aborruso at gmail.com
Tue Aug 2 02:06:16 PDT 2022
Thank you Nyall.
On Tue, 2 Aug 2022 at 00:43, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> That said, you may have some luck if you try setting the environment
> variable "OGR_SKIP=ODBC". That was required for a working mdbtools
> driver on older GDAL releases.
After running "export OGR_SKIP=ODBC", and " ogrinfo PGeo:input.mdb" I have
always
ERROR 1: PGeo: MDB Tools driver not found!
Warning 1: Unable to install MDB driver for ODBC, MDB access may not
supported.
ERROR 1: Unable to initialize ODBC connection to DSN for input.mdb,
supported.
Best regards
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220802/1c3b4f7e/attachment.htm>
