[gdal-dev] gdal_translate drops XMP exif tags
Even Rouault
even.rouault at spatialys.com
Mon Aug 8 12:13:03 PDT 2022
Tom,
It would be interesting if you could provide an image how to reproduce that
With the sample file from the autotest suite, I can't reproduce that:
$ gdal_translate ../autotest/gdrivers/data/jpeg/byte_with_xmp.jpg out.tif
$ gdalinfo out.tif -mdd all
Driver: GTiff/GeoTIFF
Files: out.tif
Size is 1, 1
Metadata (xml:XMP):
<?xpacket begin='' id='W5M0MpCehiHzreSzNTczkc9d'?>
<x:xmpmeta xmlns:x='adobe:ns:meta/' x:xmptk='Image::ExifTool 7.89'>
<rdf:RDF xmlns:rdf='http://www.w3.org/1999/02/22-rdf-syntax-ns#'>
<rdf:Description rdf:about=''
xmlns:dc='http://purl.org/dc/elements/1.1/'>
<dc:description>
<rdf:Alt>
<rdf:li xml:lang='x-default'>Description</rdf:li>
</rdf:Alt>
</dc:description>
<dc:subject>
<rdf:Bag>
<rdf:li>XMP</rdf:li>
<rdf:li>Test</rdf:li>
</rdf:Bag>
</dc:subject>
<dc:title>
<rdf:Alt>
<rdf:li xml:lang='x-default'>Title</rdf:li>
</rdf:Alt>
</dc:title>
</rdf:Description>
xmlns:tiff='http://ns.adobe.com/tiff/1.0/'>
<tiff:BitsPerSample>
<rdf:Seq>
<rdf:li>8</rdf:li>
</rdf:Seq>
</tiff:BitsPerSample>
<tiff:Compression>1</tiff:Compression>
<tiff:ImageLength>20</tiff:ImageLength>
<tiff:ImageWidth>20</tiff:ImageWidth>
<tiff:PhotometricInterpretation>1</tiff:PhotometricInterpretation>
<tiff:PlanarConfiguration>1</tiff:PlanarConfiguration>
<tiff:SamplesPerPixel>1</tiff:SamplesPerPixel>
</rdf:Description>
</rdf:RDF>
</x:xmpmeta>
<?xpacket end='w'?>
Metadata (DERIVED_SUBDATASETS):
DERIVED_SUBDATASET_1_NAME=DERIVED_SUBDATASET:LOGAMPLITUDE:out.tif
DERIVED_SUBDATASET_1_DESC=log10 of amplitude of input bands from out.tif
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 1.0)
Upper Right ( 1.0, 0.0)
Lower Right ( 1.0, 1.0)
Center ( 0.5, 0.5)
Band 1 Block=1x1 Type=Byte, ColorInterp=Gray
Le 08/08/2022 à 20:32, Tom O'Reilly a écrit :
> gdal_translate output .tif file does not contain XMP tags that were
> present in the input .jpg file.
> The output file contains many of the input EXIF tags, aggregated as
> the GDALMetadata tag, but not the XMP tags.
> Why does gdal_translate remove XMP tags - is there an option to
> preserve them?
> Thanks
> Tom
> Thomas C. O'Reilly
> Monterey Bay Aquarium Research Institute
> 7700 Sandholdt Road
> Moss Landing, California 95039-9644
> 831-775-1766 (voice)
> 831-775-1620 (FAX)
> oreilly at mbari.org (email)
> http://www.mbari.org (World-wide Web)
> "The machine does not isolate us from the great mysteries
> of nature, but plunges us more deeply into them."
> - ANTOINE DE SAINT-EXUPERY
> "Wind, Sand, and Stars" (1939)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
