[gdal-dev] Failing to write to s3 using GTiff driver.
Even Rouault
even.rouault at spatialys.com
Tue Aug 16 00:18:10 PDT 2022
William,
can you add "--debug on" and retry to see if more hints are emitted
about what's going on.
Even
Le 15/08/2022 à 11:45, William Roper a écrit :
> Hi list,
> I'm trying to convert a GeoTiff on s3 into a COG, that will also live
> on s3. I'm working on EC2 instances, or fargate containers, because
> local download and upload speeds are a bit slow.
> gdalwarp \
> --config AWS_SECRET_ACCESS_KEY <my-secret-key> \
> --config AWS_ACCESS_KEY_ID <my-access-key> \
> --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES \
> --config CPL_TMPDIR /tmp \
> -of COG
> -co TILING_SCHEME=GoogleMapsCompatible
> -co COMPRESS=DEFLATE
> -co NUM_THREADS=ALL_CPUS
> /vsis3/my-bucket/original-old-geotif.tif
> /vsis3/my-bucket/shiny-new-cog.tif
> And get the following error:
> 0...10...20...30...ERROR 1: Only read-only mode is supported for /vsicurl
> I get the same issue running in a docker container (osgeo/gdal:latest)
> or on an ubuntu EC2 instance with gdal-bin installed with apt
> (version 3.4.1).
> I can work around it by writing the COG to the machine, and then
> uploading to s3, but was wondered what I was doing wrong/not
> understanding.
> Many thanks
> Will
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220816/944754a1/attachment.htm>
