[gdal-dev] JPEG2000 via range request
Norman Barker
norman.barker at gmail.com
Fri Aug 26 09:44:53 PDT 2022
I wrote the original jpipkak driver years ago and it a driver I would
suggest for deprecation but I am no longer involved in j2k development to
know how much it is being used.
You will need a jpip server to use the jpip client. Wavelets are different
to cogs and you will get the benefits of progressive display.
Norman
On Fri, Aug 26, 2022, 5:12 PM Kurt Schwehr <schwehr at gmail.com> wrote:
> It costs, but you could try this:
> https://gdal.org/drivers/raster/jpipkak.html
> I have kakadu, but I have never tried the jpip functionality so I can't
> say how well it works.
> On Fri, Aug 26, 2022, 5:03 AM Martin <e11904212 at student.tuwien.ac.at>
> wrote:
>> Hi,
>> I want to process JP2 data via vsicurl. Which works so far.
>> Unfortunately hundreds of requests are sent, even if only the data of one
>> tile is required.
>> I understand that due to the structure of a JP2 file multiple requests
>> are necessary. But it looks like GDAL is searching every single tile
>> (resulting in ~120 requests).
>> Is there a way to reduce the number of requests?
>> I have already tried the JP2ECW-ERDAS driver, same result.
>> Do I have to configure GDAL in a certain way?
>> cmd for request:
>> #!/bin/bash
>> export GDAL_DISABLE_READDIR_ON_OPEN="YES"
>> export CPL_VSIL_CURL_ALLOWED_EXTENSIONS="jp2"
>> export CPL_CURL_VERBOSE="YES"
>> export GDAL_HTTP_MERGE_CONSECUTIVE_RANGES="YES"
>> gdal_translate --debug ON -srcwin 0 0 256 256 /vsicurl/
>> http://localhost:8083/T33UWP_20220515T100031_TCI_10m_J2Lmin.jp2
>> ./out_subWin.tif
>> What options do I need to specify when creating the JP2 file to support
>> GDAL?
>> Currently I use the following options:
>> #!/bin/bash
>> gdal_translate \
>> -of JP2OpenJPEG \
>> -co QUALITY=100 \
>> -co TLM=YES \
>> -co PLT=YES \
>> -co PROGRESSION=LRCP \
>> -co WRITE_METADATA=YES \
>> ../test_data/T33UWP_20220515T100031_TCI_10m.tif \
>> ./T33UWP_20220515T100031_TCI_10m_J2Lmin.jp2
>> Some logs:
>> [gdal degug output](https://pastebin.com/vTf7tjLJ)
>> [nginx logs](https://pastebin.com/8bWW15Tp)
>> [gdalinfo](https://pastebin.com/HWSmypEQ)
>> [opj_dump](https://pastebin.com/rdYbHEnY)
>> [kdu_jp2info](https://pastebin.com/atVUfeVx)
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220826/b7750370/attachment.htm>
