[gdal-dev] use gdal_viewshed
Bradner, Kevin M. (ARC-TI) kevin.bradner at nasa.gov
Mon Aug 29 16:45:29 PDT 2022
Hello,
I'm interested in using gdal_viewshed<https://gdal.org/programs/gdal_viewshed.html#gdal-viewshed> to calculate a viewshed for a point on the surface of the Moon. My DEM stores heights relative to a reference sphere approximately the size of the Moon.
Could I calculate a valid viewshed from this data by passing in a -cc of roughly 3.6 (Earth diameter / Moon diameter)? Some comments in the algorithm's source code make this seem reasonable, but I would like to confirm that this is the only correction I would need to make.
Thank you,
Kevin Bradner
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220829/4018afd2/attachment.htm>
