[gdal-dev] Build of gdal fails on missing OSGeo.GDAL.Core
Rob Stevens
phlebas at cantab.net
Fri Dec 2 04:35:28 PST 2022
I am very new to building out GIS tools on the MacOS platform,
so I apologize for my rather turgid description below.
I am trying to build gdal 3.6.0 (git cloned)
on macos catalina 10.15.7 on a macbook pro 2017
On this machine I have various versions of Msoft dotnet core sdks installed
(7.0.100, 6.0.403, 6.0.401, 2.1.500)
All goes well until the build gets 88% done.
Then I see:
======= Building .NET project OSGeo.OSR [Release ]
Determining projects to restore...
/usr/local/share/dotnet/sdk/7.0.100/Sdks/Microsoft.NET.Sdk/targets/Microsoft.NET.EolTargetFrameworks.targets(28,5):
warning NETSDK1138: The target framework 'net5.0' is out of support and
will not receive security updates in the future. Please refer to
https://aka.ms/dotnet-core-support for more information about the
support policy.
[/Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj]
Writing /var/folders/15/nt94jgd930z_z6zr5gc081y00000gr/T/tmpUJ1Fvw.tmp
info : X.509 certificate chain validation will use the fallback
certificate bundle at
'/usr/local/share/dotnet/sdk/7.0.100/trustedroots/codesignctl.pem'.
'/usr/local/share/dotnet/sdk/7.0.100/trustedroots/timestampctl.pem'.
info : Restoring packages for
/Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj...
info : GET
https://api.nuget.org/v3-flatcontainer/osgeo.gdal.core/index.json
info : NotFound
https://api.nuget.org/v3-flatcontainer/osgeo.gdal.core/index.json 1316ms
error: NU1101: Unable to find package OSGeo.GDAL.Core. No packages exist
with this id in source(s): nuget.org
error: Package 'OSGeo.GDAL.Core' is incompatible with 'all' frameworks
in project
'/Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj'
It is not my intent to build any dotnet components/interfaces
but the cmake build seems to want to do this just by virtue
of my having dotnet SDKs installed. The cmake build files
are very difficult to understand, and I have not yet been
able to figure out how to prevent these unneeded
components being built.
1. How do I prevent these dotnet components being built?
2. It seems as though I am trying to build against all versions of the
dotnet
SDK installed, but some of those versions do not have nuget packages
for OSGeo.GDal.Core.
Regardless of my needs, is this not a larger problem in the build?
Thanks for any help.
Rob Stevens
