[gdal-dev] Build of gdal fails on missing OSGeo.GDAL.Core
Paul Harwood
runette at gmail.com
Fri Dec 2 04:58:11 PST 2022
sorry - cut and paste error. That should have been
-DBUILD_CSHARP_BINDINGS=OFF
On Fri, 2 Dec 2022 at 12:53, Paul Harwood <runette at gmail.com> wrote:
> I can have a think about what is causing the problem - but the simplest
> fix if you don't want the c# bindings is to build with
> -DBUILD_CSHARP_BINDINGS:BOOLOFF
> More on the compile switches here
> https://gdal.org/development/building_from_source.html#cmdoption-arg-BUILD_CSHARP_BINDINGS-BOOL
> On Fri, 2 Dec 2022 at 12:45, Rob Stevens <phlebas at cantab.net> wrote:
>> I am very new to building out GIS tools on the MacOS platform,
>> so I apologize for my rather turgid description below.
>> I am trying to build gdal 3.6.0 (git cloned)
>> on macos catalina 10.15.7 on a macbook pro 2017
>> On this machine I have various versions of Msoft dotnet core sdks
>> installed
>> (7.0.100, 6.0.403, 6.0.401, 2.1.500)
>> All goes well until the build gets 88% done.
>> Then I see:
>> ======= Building .NET project OSGeo.OSR [Release ]
>> Determining projects to restore...
>> /usr/local/share/dotnet/sdk/7.0.100/Sdks/Microsoft.NET.Sdk/targets/Microsoft.NET.EolTargetFrameworks.targets(28,5):
>> warning NETSDK1138: The target framework 'net5.0' is out of support and
>> will not receive security updates in the future. Please refer to
>> https://aka.ms/dotnet-core-support for more information about the
>> support policy.
>> [/Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj]
>> Writing /var/folders/15/nt94jgd930z_z6zr5gc081y00000gr/T/tmpUJ1Fvw.tmp
>> info : X.509 certificate chain validation will use the fallback
>> certificate bundle at
>> '/usr/local/share/dotnet/sdk/7.0.100/trustedroots/codesignctl.pem'.
>> '/usr/local/share/dotnet/sdk/7.0.100/trustedroots/timestampctl.pem'.
>> info : Restoring packages for
>> /Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj...
>> info : GET
>> https://api.nuget.org/v3-flatcontainer/osgeo.gdal.core/index.json
>> info : NotFound
>> https://api.nuget.org/v3-flatcontainer/osgeo.gdal.core/index.json 1316ms
>> error: NU1101: Unable to find package OSGeo.GDAL.Core. No packages exist
>> with this id in source(s): nuget.org
>> error: Package 'OSGeo.GDAL.Core' is incompatible with 'all' frameworks
>> in project
>> '/Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj'
>> It is not my intent to build any dotnet components/interfaces
>> but the cmake build seems to want to do this just by virtue
>> of my having dotnet SDKs installed. The cmake build files
>> are very difficult to understand, and I have not yet been
>> able to figure out how to prevent these unneeded
>> components being built.
>> 1. How do I prevent these dotnet components being built?
>> 2. It seems as though I am trying to build against all versions of the
>> dotnet
>> SDK installed, but some of those versions do not have nuget packages
>> for OSGeo.GDal.Core.
>> Regardless of my needs, is this not a larger problem in the build?
>> Thanks for any help.
>> Rob Stevens
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221202/92a618e0/attachment.htm>
