[gdal-dev] Build of gdal fails on missing OSGeo.GDAL.Core
Paul Harwood runette at gmail.com
Fri Dec 2 15:56:11 PST 2022
PR proposed related to this https://github.com/OSGeo/gdal/pull/6843
On Fri, 2 Dec 2022 at 13:18, Paul Harwood <runette at gmail.com> wrote:
> BTW - I am fairly certain that the error messages are because the .NET SDK
> release default is still set as .NET 5  and reading your email - you don't
> have .NET 5. Since you did not set the .NET release - it is trying to use
> the default.
> I think the error messages could be a lot better! I can have a look at
> that.
> I guess that defaulting to .NET 5 is no longer ideal. I can have a look at
> that as well.
> On Fri, 2 Dec 2022 at 12:58, Paul Harwood <runette at gmail.com> wrote:
>> sorry - cut and paste error. That should have been
>> -DBUILD_CSHARP_BINDINGS=OFF
>> On Fri, 2 Dec 2022 at 12:53, Paul Harwood <runette at gmail.com> wrote:
>>> I can have a think about what is causing the problem - but the simplest
>>> fix if you don't want the c# bindings is to build with
>>> -DBUILD_CSHARP_BINDINGS:BOOLOFF
>>> More on the compile switches here
>>> https://gdal.org/development/building_from_source.html#cmdoption-arg-BUILD_CSHARP_BINDINGS-BOOL
>>> On Fri, 2 Dec 2022 at 12:45, Rob Stevens <phlebas at cantab.net> wrote:
>>>> I am very new to building out GIS tools on the MacOS platform,
>>>> so I apologize for my rather turgid description below.
>>>> I am trying to build gdal 3.6.0 (git cloned)
>>>> on macos catalina 10.15.7 on a macbook pro 2017
>>>> On this machine I have various versions of Msoft dotnet core sdks
>>>> installed
>>>> (7.0.100, 6.0.403, 6.0.401, 2.1.500)
>>>> All goes well until the build gets 88% done.
>>>> Then I see:
>>>> ======= Building .NET project OSGeo.OSR [Release ]
>>>>    Determining projects to restore...
>>>> /usr/local/share/dotnet/sdk/7.0.100/Sdks/Microsoft.NET.Sdk/targets/Microsoft.NET.EolTargetFrameworks.targets(28,5):
>>>> warning NETSDK1138: The target framework 'net5.0' is out of support and
>>>> will not receive security updates in the future. Please refer to
>>>> https://aka.ms/dotnet-core-support for more information about the
>>>> support policy.
>>>> [/Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj]
>>>>    Writing
>>>> /var/folders/15/nt94jgd930z_z6zr5gc081y00000gr/T/tmpUJ1Fvw.tmp
>>>> info : X.509 certificate chain validation will use the fallback
>>>> certificate bundle at
>>>> '/usr/local/share/dotnet/sdk/7.0.100/trustedroots/codesignctl.pem'.
>>>> '/usr/local/share/dotnet/sdk/7.0.100/trustedroots/timestampctl.pem'.
>>>> info : Restoring packages for
>>>> /Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj...
>>>> info :   GET
>>>> https://api.nuget.org/v3-flatcontainer/osgeo.gdal.core/index.json
>>>> info :   NotFound
>>>> 1316ms
>>>> error: NU1101: Unable to find package OSGeo.GDAL.Core. No packages
>>>> exist
>>>> with this id in source(s): nuget.org
>>>> error: Package 'OSGeo.GDAL.Core' is incompatible with 'all' frameworks
>>>> in project
>>>> '/Users/rob/tmp/git_checkouts/gdal/build/swig/csharp/osr/osr_csharp.csproj'
>>>> It is not my intent to build any dotnet components/interfaces
>>>> but the cmake build seems to want to do this just by virtue
>>>> of my having dotnet SDKs installed. The cmake build files
>>>> are very difficult to understand, and I have not yet been
>>>> able to figure out how to prevent these unneeded
>>>> components being built.
>>>> 1. How do I prevent these dotnet components being built?
>>>> 2. It seems as though I am trying to build against all versions of the
>>>> dotnet
>>>>      SDK installed, but some of those versions do not have nuget
>>>> packages
>>>>      for OSGeo.GDal.Core.
>>>>      Regardless of my needs, is this not a larger problem in the build?
>>>> Thanks for any help.
>>>> Rob Stevens
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221202/38621370/attachment.htm>
