[gdal-dev] gdal_merge
Clive Swan
cliveswan at gmail.com
Mon Dec 5 02:24:14 PST 2022
Hi Even,
Thanks
the –configuration sorted out that issue.
CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE is a configuration option /
environment variable, so you have to pass it with --config
CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
Now I am getting a memory issue?? << The input files are 6.9 GB + 672 MB
The output should be 7.xx GB
6.9 GB + 672MB
numpy.core._exceptions._ArrayMemoryError: Unable to allocate 377. GiB for
an array with shape (225000, 450000) and data type float32
Any suggestions appreciated
Kind regards,
Clive
Regards,
Clive Swan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221205/df8c6525/attachment.htm>
