[gdal-dev] gdal_merge
Clive Swan
cliveswan at gmail.com
Mon Dec 5 03:46:49 PST 2022
The raster one is the world, the second is the UK.
The UK fits within the first raster...
We want to update UK data in raster one.
Regards,
Clive
Get Outlook for Android<https://aka.ms/AAb9ysg>
From: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Sent: Monday, December 5, 2022 11:34:53 AM
To: Clive Swan <cliveswan at gmail.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] gdal_merge
Maybe your rasters are far apart. Gdal_merge creates a raster with so large extent that all the source images fit within it. Even empty pixels take space.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Clive Swan
Lähetetty: maanantai 5. joulukuuta 2022 12.24
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] gdal_merge
Hi Even,
Thanks
the –configuration sorted out that issue.
CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE is a configuration option /
environment variable, so you have to pass it with --config
CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
Now I am getting a memory issue?? << The input files are 6.9 GB + 672 MB
The output should be 7.xx GB
6.9 GB + 672MB
numpy.core._exceptions._ArrayMemoryError: Unable to allocate 377. GiB for an array with shape (225000, 450000) and data type float32
Any suggestions appreciated
Kind regards,
Clive
Regards,
Clive Swan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221205/b63bcb75/attachment-0001.htm>
