[gdal-dev] SQL query to set column to GPKG raster pixel value of point intersection result
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Thu Dec 8 10:07:00 PST 2022
I have GPKG database with features represented by point geometries.  I’d like to update these features, in a single SQL statement, to add a new column whose value is the pixel value of an external GPKG raster for which the point geometry intersects with.  I was hoping to find an OGR SQL function similar to burn for this, but I’ve come up empty handed.
Is this functionality available? Ideally, without resorting to manually updating each feature individually in a user application.  Otherwise, perhaps a feature request is in order.
Thanks,
Jesse
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221208/4613a168/attachment.htm>
