[gdal-dev] [EXTERNAL] Re: SQL query to set column to GPKG raster pixel value of point intersection result
Even Rouault
even.rouault at spatialys.com
Thu Dec 8 14:04:31 PST 2022
That sounds like a cool idea. I've had a crack at it in
https://github.com/OSGeo/gdal/pull/6877
Even
Le 08/12/2022 à 22:10, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev a écrit :
> Hi,
> I want to perform this on tens of thousands of GPKG databases, each
> possessing upwards of millions of points, so automation (and
> performance) is a high value. The hope was that given both data
> sources leverage the same driver, there was some hope of this working
> with the proper incantation, especially considering the library
> routines available by Spatialite in SQL queries. But without
> something like burn available in a SQL query then this can’t work at
> the query level. This is easy to write in C/C++ but wanted to see if
> the database engine could handle it directly.
> Jesse
> *From: *Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Date: *Thursday, December 8, 2022 at 3:45 PM
> *To: *"Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS
> INC]" <jesse.r.meyer at nasa.gov>, "gdal-dev at lists.osgeo.org"
> <gdal-dev at lists.osgeo.org>
> *Subject: *[EXTERNAL] Re: SQL query to set column to GPKG raster pixel
> Hi,
> It feels like quite special tool. Have you considered to use the
> Sample Raster Values tool in QGIS? The description of the tool is:
> Sample raster values
> This algorithm creates a new vector layer with the same attributes of
> the input layer and the raster values corresponding on the point location.
> If the raster layer has more than one band, all the band values are
> sampled.
> -Jukka Rahkonen-
> *Lähettäjä:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]
> via gdal-dev
> *Lähetetty:* torstai 8. joulukuuta 2022 20.07
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] SQL query to set column to GPKG raster pixel value
> Hi,
> I have GPKG database with features represented by point geometries.
> I’d like to update these features, in a single SQL statement, to add a
> new column whose value is the pixel value of an external GPKG raster
> for which the point geometry intersects with. I was hoping to find an
> OGR SQL function similar to burn for this, but I’ve come up empty handed.
> Is this functionality available? Ideally, without resorting to
> manually updating each feature individually in a user application.
> Otherwise, perhaps a feature request is in order.
> Thanks,
> Jesse
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221208/b21f0755/attachment.htm>
