[gdal-dev] GDAL python API - Data axis to CRS axis mapping
Even Rouault
even.rouault at spatialys.com
Sat Dec 10 11:55:03 PST 2022
Hi Chris,
https://gdal.org/api/python/osgeo.osr.html#osgeo.osr.SpatialReference.GetDataAxisToSRSAxisMapping
Doc:
https://gdal.org/api/ogrspatialref.html#_CPPv4NK19OGRSpatialReference27GetDataAxisToSRSAxisMappingEv
Example at
https://github.com/OSGeo/gdal/blob/9452625baa544ea3ab6bb0b3e368023434011ea7/autotest/gcore/vrt_read.py#L1339
Even
Le 10/12/2022 à 20:06, Chris Crook a écrit :
> Hi
> I am using the GDAL python API and trying to determine the data axis
> to CRS axis mapping. This is displayed by gdalinfo, eg looking at
> test.tif file I have:
> Data axis to CRS axis mapping: 2,1
> However I can't see how to access this in the API. I have looked at
> the tolatlong.py sample, and but this looks like it is about
> converting projections, which I think is a different thing. What I am
> looking for is the correct mapping from the lat/lon order generated by
> the geotransform to the order defined by the CRS WKT.
> Can anyone advise on how to best access this mapping?
> Thanks
> Chris Crook
> This message contains information, which may be in confidence and may
> be subject to legal privilege. If you are not the intended recipient,
> you must not peruse, use, disseminate, distribute or copy this
> message. If you have received this message in error, please notify us
> immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the
> original message. LINZ accepts no responsibility for changes to this
> email, or for any attachments, after its transmission from LINZ. Thank
> You.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221210/73e6b7f8/attachment.htm>
