[gdal-dev] ERROR 13: The specified key does not exist
Clive Swan
cliveswan at gmail.com
Mon Dec 12 01:33:55 PST 2022
Greetings,
I have been using the security details for weeks, now getting an odd error.
AWS_ACCESS_KEY_ID
AWS_SECRET_ACCESS_KEY
*ERROR 4:* Attempt to create new tiff file `/vsis3/summer-outputs/3/coastal-
-2020.tif' failed: Permission denied
Input file size is 450000, 225000*ERROR 13*: The specified key does
not exist *<< ??*
*### Script below*
#!/bin/bash
LOG_FILE=/home/ubuntu/run_translate.log
exec 1>>${LOG_FILE}
exec 2>>${LOG_FILE}
## 5_UK_rasters >> 3_data_ready
gdal_translate /vsis3/summer-outputs/5/coastal-2020.vrt /vsis3/
summer-outputs/3/coastal-2020.tif -co BIGTIFF=YES -co
NUM_THREADS=ALL_CPUS --config GDAL_CACHEMAX 100000 --config CPL_TMPDIR
/data/tmp --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
--config AWS_ACCESS_KEY_ID KEY_ID --config AWS_SECRET_ACCESS_KEY
ACCESS_KEY
echo end script
Regards,
Clive Swan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221212/13c88ee2/attachment-0001.htm>
