[gdal-dev] Ogr2ogr: when both -update and -append is needed?
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Mon Dec 12 12:25:41 PST 2022
I saw this question https://gis.stackexchange.com/questions/447359/what-is-the-effect-of-using-update-when-merging-geojsons-with-ogr2ogr and started to think when the ogr2ogr option -update is needed even when the -append option is used. At least for some drivers -append alone seems to be enough but are there some drivers that explicitly require also -update?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221212/0c3a1199/attachment.htm>
