[gdal-dev] gdal_merge tries create 377 GB raster
Clive Swan cliveswan at gmail.com
Mon Dec 12 13:48:56 PST 2022
/data/coastal.tif  should be 6.9GB
I get weird output from gdal_merge??
gdal_merge.py -o /data/coastal.tif -n -9999 -co BIGTIFF=YES -co
COMPRESS=LZW -co BLOCKXSIZE=128 -co BLOCKYSIZE=128  -co
NUM_THREADS=ALL_CPUS --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
 --config GDAL_SWATH_SIZE 1000000  /vsis3/summer/1/coastal.tif
/vsis3/summer/2/coastal.tif  & disown -h
[1] 507311
ubuntu at ip-172-31-31-16:~$ 0Traceback (most recent call last):
  File "/usr/bin/gdal_merge.py", line 11, in <module>
    sys.exit(main(sys.argv))
  File "/usr/lib/python3/dist-packages/osgeo_utils/gdal_merge.py", line
530, in main
    fi.copy_into(t_fh, band, band, nodata, verbose)
284, in copy_into
    return raster_copy(s_fh, sw_xoff, sw_yoff, sw_xsize, sw_ysize, s_band,
  File "/usr/lib/python3/dist-packages/osgeo_utils/gdal_merge.py", line 56,
in raster_copy
    return raster_copy_with_nodata(
  File "/usr/lib/python3/dist-packages/osgeo_utils/gdal_merge.py", line 96,
in raster_copy_with_nodata
    data_src = s_band.ReadAsArray(s_xoff, s_yoff, s_xsize, s_ysize,
  File "/usr/lib/python3/dist-packages/osgeo/gdal.py", line 3653, in
ReadAsArray
    return gdal_array.BandReadAsArray(self, xoff, yoff,
  File "/usr/lib/python3/dist-packages/osgeo/gdal_array.py", line 422, in
BandReadAsArray
    buf_obj = numpy.empty([buf_ysize, buf_xsize], dtype=typecode)
numpy.core._exceptions._ArrayMemoryError: Unable to allocate 377. GiB for
an array with shape (225000, 450000) and data type float32
 Regards,
Clive Swan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221212/e03612fd/attachment.htm>
