[gdal-dev] Advanced 3.6.1 release and retraction of 3.6.0 ?
Sean Gillies
sean.gillies at gmail.com
Tue Dec 13 07:40:44 PST 2022
No objection from me!
On Tue, Dec 13, 2022, 8:19 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> https://github.com/qgis/QGIS/issues/51188 has been brought to my
> attention. The issue is that the new background building of the RTree of
> GeoPackage files introduced in 3.6.0 didn't work well with committing
> transactions in between, which is easily triggered by ogr2ogr. All
> features were inserted but with default settings ~ 10% of them lacked an
> entry in the spatial index, which can be enough to break interactive
> display and workflows relying on spatial filtering. When using ogr2ogr,
> I believe the issue can only be seen when creating layers with more than
> 100 000 features, since that's the default value for the interval at
> which transactions are committed.
> I've a fix ready in https://github.com/OSGeo/gdal/pull/6911. The fix
> itself is a simple two-liner:
> https://github.com/OSGeo/gdal/pull/6911/commits/3f5f6225fe82e0c2e0241e4f66bfb861cdf4fe9d
> Given the status of GeoPackage being the default format for QGIS, I
> believe this is a severe enough issue to warrant an advanced 3.6.1
> release, and an official retraction of 3.6.0.
> Thoughts ?
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221213/f50801b1/attachment.htm>
