[gdal-dev] [Tiff] libtiff v4.5.0 rc2 available
Even Rouault even.rouault at spatialys.com
Tue Dec 13 13:47:56 PST 2022
Hi Kurt,
thanks for the feedback (and invalidating my prophecy that rc2 would be
the last one :-))
should be fixed with
https://gitlab.com/libtiff/libtiff/-/merge_requests/444.
Is that enough to get the build working for you before I generate a rc3
with that extra fix ?
Even
Le 13/12/2022 à 22:39, Kurt Schwehr a écrit :
> I'm seeing mac osx and ios failures at my most recent sync of
> c4516f9dc72bad7f2c4a8f704169afa0342e44ca
> <https://www.google.com/url?sa=D&q=https%3A%2F%2Fgitlab.com%2Flibtiff%2Flibtiff%2Fcommit%2Fc4516f9dc72bad7f2c4a8f704169afa0342e44ca>:
> third_party/tiff/libtiff/tif_dir.c:1988:17: error: format specifies
> type 'unsigned short' but the argument has type 'tdir_t' (aka
> 'unsigned int') [-Werror,-Wformat]
>                 *nextdirnum, *nextdiroff, *nextdiroff,
> (int)(*nextdirnum) - 1);
> third_party/tiff/libtiff/tif_dir.c:2164:27: error: format specifies
>                           dirn);
> On Tue, Dec 13, 2022 at 12:39 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Hi,
>     The changes in IFD loop detection are non-trivial enough to justify a
>     rc2, so here it is:
>     - https://download.osgeo.org/libtiff/tiff-4.5.0rc2.tar.gz
>     - https://download.osgeo.org/libtiff/tiff-4.5.0rc2.tar.gz.sig
>     - https://download.osgeo.org/libtiff/tiff-4.5.0rc2.tar.xz
>     - https://download.osgeo.org/libtiff/tiff-4.5.0rc2.tar.xz.sig
>     - https://download.osgeo.org/libtiff/tiff-4.5.0rc2.zip
>     - https://download.osgeo.org/libtiff/tiff-4.5.0rc2.zip.sig
>     Hopefully this will be the final release candidate for 4.5.0. Please
>     test and report.
>     The changes since rc1 are:
>     - restore formatting of tiffvers.h so that FindTIFF.cmake can infer
>     libtiff version number
>     - addition of TIFFLIB_MAJOR_VERSION, TIFFLIB_MINOR_VERSION,
>     TIFFLIB_MICRO_VERSION in tiffvers.h
>     - introduction of TIFFLIB_AT_LEAST(major, minor, micro) macro in
>     tiffvers.h
>     - CMake: restore BUILD_SHARED_LIBS=ON default setting for
>     top-level builds
>     - IFD loop detection: changed algorithm to use a hashset/hashmap for
>     good performance
>     - tdir_t type updated to uint32_t. This type is now used for the
>     return
>     value of TIFFCurrentDirectory and TIFFNumberOfDirectories, and as the
>     argument of TIFFSetDirectory and TIFFUnlinkDirectory
>     - Increase the maximum number of IFDs that libtiff can browse through
>     from 65535 to 1048576. This value is a build-time setting,
>     available in
>     tif_config.h, that can be configured with CMake's
>     TIFF_MAX_DIR_COUNT and
>     variable or autoconf's --with-max-dir-count option.
>     - tiffinfo: support more than 64k IFDs.
>     Even
>     http://www.spatialys.com
>     My software is free, but my time generally not.
>     _______________________________________________
>     Tiff mailing list
>     Tiff at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/tiff
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221213/c7018b62/attachment.htm>
