[gdal-dev] Move pixel ULx ULy - what is dx_dy + dy_dx
Clive Swan
cliveswan at gmail.com
Fri Dec 16 02:10:34 PST 2022
Greetings,
I want to shift the UL x, UL y of an image.
I am trying to find out what the *dx_dy + dy_dx* is.
The code is:
import gdal
### open dataset with update permission
ds = gdal.Open('/data/coastal-2020.tif', gdal.GA_Update)
### get the geotransform as a tuple of 6
gt = ds.GetGeoTransform()
### unpack geotransform into variables
x_tl = (-180.0000000)
x_res = 0.000800000000000
*dx_dy* =
y_tl = (90.0000000)
*dy_dx* =
y_res = -0.000800000000000
x_tl, x_res, *dx_dy*, y_tl, *dy_dx*, y_res = gt
# compute shift of 1 pixel RIGHT in X direction
shift_x = 1 * x_res
# compute shift of 2 pixels UP in Y direction
# y_res likely negative, because Y decreases with increasing Y index
shift_y = -2 * y_res
# make new geotransform
gt_update = (x_tl + shift_x, x_res, dx_dy, y_tl + shift_y, dy_dx, y_res)
>From gdalinfo:
Size is 450000, 225000
Coordinate System is:
GEOGCRS["WGS 84",
DATUM["World Geodetic System 1984",
ELLIPSOID["WGS 84",6378137,298.257223563,
LENGTHUNIT["metre",1]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
CS[ellipsoidal,2],
AXIS["geodetic latitude (Lat)",north,
ORDER[1],
AXIS["geodetic longitude (Lon)",east,
ORDER[2],
ID["EPSG",4326]]
Data axis to CRS axis mapping: 2,1
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.000800000000000,-0.000800000000000)
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
PREDICTOR=3
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0' 0.01"N)
Regards,
Clive Swan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221216/e99b9349/attachment.htm>
