[gdal-dev] std::numeric_limits<int64_t>::min() vs LLONG_MIN
Andrew C Aitchison
andrew at aitchison.me.uk
Sun Dec 18 09:39:11 PST 2022
On Sun, 18 Dec 2022, Paul Meems wrote:
> Thanks all for your suggestions.
> I did some more research and it seems to be an issue with the preprocessor
> on Windows.
> Adding some brackets solves the issue as well:
> // old
> constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =
> std::numeric_limits<int64_t>::min();
> constexpr uint64_tGDAL_PAM_DEFAULT_NODATA_VALUE_UINT64=
> std::numeric_limits<uint64_t>::max();
> // new:
> constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =*(*
> std::numeric_limits<int64_t>::min*)*();
> constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 =*(*
> std::numeric_limits<uint64_t>::max*)*();
Do you mean to add *(* and *)* or just ( and ) ?
> I'm not sure what the impact would be for non-windows compilers, but if no
> impact could this be changed in the code?
> Thanks,
> Paul Meems
> Op za 17 dec. 2022 om 07:10 schreef <dg0yt at darc.de>:
>> I'm not using MSVC, so this is a guess:
>> Are you including 'windows.h' without 'NOMINMAX' being defined?
>> Then you will get macros which interfere with the limits code.
>> Regards, Kai.
>>> Paul Meems <bontepaarden at gmail.com> hat am 17.12.2022 00:46 CET
>> geschrieben:
>>> Thanks, Kurt for your response.
>>> I'm getting a very vague error message:
>>> E0040 expected an identifier.
>>> Regards,
>>> Paul
>>> Op za 17 dec. 2022 om 00:40 schreef Kurt Schwehr <schwehr at gmail.com>:
>>>> What exact error are you getting?
>>>> On Fri, Dec 16, 2022 at 3:31 PM Paul Meems <bontepaarden at gmail.com>
>> wrote:
>>>>> Hello List,
>>>>> We're trying to update MapWinGIS which is using the GDAL libraries
>> from gisinternals.com (http://gisinternals.com)
>>>>> Currently, we use the stable daily of December
>> 9: release-1928-gdal-3-5-mapserver-8-0
>>>>> I'm using VS2019 (on Windows) to compile and I'm having issues with
>> two lines in gdal_pam.h, around line 215.
>>>>> We need to change these two lines:
>>>>> * constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =
>>>>> * constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 =
>>>>> To
>> LLONG_MIN;
>> LLONG_MAX;
>>>>> I prefer not to alter the files from gisinternals.com (
>> http://gisinternals.com). Is this what we can solve on our end?
>>>>> Is it related to the C++ version? We use these:
>>>>> * ISO C++14 Standard (/std:c++14)
>>>>> * ISO C11 Standard (/std:c11)
>>>>> Thanks for any advice.
>>>>> Paul Meems
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Andrew C. Aitchison Kendal, UK
